https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> writing transient node data to a file(in text format) https://designers-guide.org/forum/YaBB.pl?num=1223955583 Message started by paddu on Oct 13th, 2008, 8:39pm |
Title: writing transient node data to a file(in text format) Post by paddu on Oct 13th, 2008, 8:39pm how to write transient data of a particular node to a file (in text format) in cadence spectre? (EX : if it is voltage waveform, how to output Volatge vs time inforamtion in to a file(in text format)) |
Title: Re: writing transient node data to a file(in text format) Post by Ken Kundert on Oct 13th, 2008, 9:37pm Easily done with Verilog-A. Just use a strobe statement in the analog block. -Ken |
Title: Re: writing transient node data to a file(in text format) Post by ywguo on Oct 20th, 2008, 3:27am Print it with the Calculator in the Analog Design Environment. Yawei |
