https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> verilog code in verilogA https://designers-guide.org/forum/YaBB.pl?num=1225278077 Message started by manodipan on Oct 29th, 2008, 4:01am |
Title: verilog code in verilogA Post by manodipan on Oct 29th, 2008, 4:01am Hi all, I have a mixed signal circuit .Now do verilog A support code written using verilog (like @posedge(clk))..if not then which way i can write codes for both environments.... Manodipan |
Title: Re: verilog code in verilogA Post by jbdavid on Oct 29th, 2008, 10:00am Verilog-A is the analog subset. It will work in a spectre(or spice) netlist.. or in a verilog netlist. Verilog-AMS is the mixed signal language. Its a superset of Verilog-A and Verilog, with some extra for dealing with the interface. you can use the verilog-A model in the verilog netlist.. but you cant use the verilog-ams model in the spectre netlist. |
Title: Re: verilog code in verilogA Post by patrick on Oct 29th, 2008, 10:38am I think you need to use the predefined macro, __VAMS_ENABLE__. See page 239 of the VAMS 2.3 LRM at, http://www.verilog.org/verilog-ams/htmlpages/public-docs/lrm/2.3/VAMS-LRM-2-3.pdf Verilog-AMS HDL supports a predefined macro to allow modules to be written that work with both IEEE std 1364-2005 Verilog HDL and Verilog-AMS HDL.The predefined macro is called __VAMS_ENABLE__. This macro shall always be defined during the parsing of Verilog-AMS source text. Its purpose is to support the creation of modules which are both legal Verilog and Verilog-AMS. The Verilog-AMS features of such modules are made visible only when the __VAMS_ENABLE__ macro has previously been defined. Example: module not_gate(in, out); input in; output out; reg out; `ifdef __VAMS_ENABLE__ parameter integer del = 1 from [1:100]; `else parameter del = 1; `endif always @ in out = #del !in; endmodule |
