https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Truly bidirectional ideal transformer in Verilog-A https://designers-guide.org/forum/YaBB.pl?num=1227781802 Message started by gmork_0 on Nov 27th, 2008, 2:30am |
Title: Truly bidirectional ideal transformer in Verilog-A Post by gmork_0 on Nov 27th, 2008, 2:30am Hi, In Spectre, there is an ideal transformer component (called transformer). This one is "truly" bidirectional - one can force the current or voltage (connect ideal current or voltage source) to either primary or secondary winding. i just wondered, if such a component can be written in Verilog-A as well.My best try was: module idealTransformer(pLeft, nLeft, pRight, nRight); parameter real ratio = 2 from (0:inf); inout pLeft, nLeft, pRight, nRight; electrical pLeft, nLeft, pRight, nRight; analog begin V(pRight,nRight) <+ ratio*V(pLeft, nLeft); I(pLeft,nLeft) <+ -ratio*I(pRight, nRight); end endmodule ,what works fine for real loading of ports. However, one cannot e.g. connect the ideal voltage source to the pRight, nRight ports. Thanks for comments, Miro |
Title: Re: Truly bidirectional ideal transformer in Verilog-A Post by Geoffrey_Coram on Dec 3rd, 2008, 5:34am I replaced your V line with an indirect assignment: V(pRight,nRight) : V(pRight,nRight) == ratio*V(pLeft, nLeft); and it seems to work with a v-source on either side. |
