https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> CMFB for pseudo differential amplifier https://designers-guide.org/forum/YaBB.pl?num=1228281440 Message started by yixiusky on Dec 2nd, 2008, 9:17pm |
Title: CMFB for pseudo differential amplifier Post by yixiusky on Dec 2nd, 2008, 9:17pm I would like to ask one question: when we design pseudo differential amplifier, the common mode feedback circuit also should pseudo differential (without tail current source) or not ? thank you very much |
Title: Re: CMFB for pseudo differential amplifier Post by loose-electron on Dec 5th, 2008, 1:13pm Could you please better define the question? Differential architectures I think we all understand, Complimentary architectures most of us understand. but what is "pseudo differential?" thanks - Jerry |
Title: Re: CMFB for pseudo differential amplifier Post by rf-design on Dec 15th, 2008, 1:59pm Pseudo-differential means two single-ended stages used with complementary signals. Typical no common-mode rejection but if the signals are used as differential cancelation of some negative effects could occur. No commom mode control needed. If the single-ended stages make a level shift between in and out and you can control that this will be a common mode control. |
