https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Low to High Voltage Level Shifter https://designers-guide.org/forum/YaBB.pl?num=1228427857 Message started by wave on Dec 4th, 2008, 1:57pm |
Title: Low to High Voltage Level Shifter Post by wave on Dec 4th, 2008, 1:57pm Hello - Can anyone suggest good architectures (papers?) of Logic Level shifters. I need a low voltage (say 1V) shifted to a higher voltage (variable, 3-10V) range. I have various oxide devices and Vt flavors. One complicating issue is, the lower supply may fall away and the output should remain in state. ie, latched. Once we have a latching mechanism, a 2nd issues is the condition on startup. It needs a skew or POR, perhaps. Finally, I cannot tolerate DC current in either high or low state. One idea is a cross coupled NOR gate, like an R/S latch. thanks for your comments. ~WAVE :P |
Title: Re: Low to High Voltage Level Shifter Post by rf-design on Dec 15th, 2008, 2:59pm The crosscoupled PMOS with NMOS driven from 1V-logic works only if the gate could withstand 10V. That is rare to my knowledge. If the the high voltage logic is e.g. between 10V and 7.5V made of thick-oxide with isolated NMOS then the latch must be current controlled from the 1V-0V-logic. The latch could have a normal asynchron reset. Is the voltage like above? What process you use? |
Title: Re: Low to High Voltage Level Shifter Post by wave on Dec 15th, 2008, 3:18pm rf-design wrote on Dec 15th, 2008, 2:59pm:
In this case, I do actually have 10V xters to run the latch off of. However, this is also a general problem with multiple supplies. I know some guys have to level shift 1.8 to 3V, using dual gate Oxide transistor. Or 1V to 2.5V, etc. regards, Wave |
