https://designers-guide.org/forum/YaBB.pl Modeling >> Semiconductor Devices >> n+ polysilicon gates https://designers-guide.org/forum/YaBB.pl?num=1231223011 Message started by Berti on Jan 5th, 2009, 10:23pm |
Title: n+ polysilicon gates Post by Berti on Jan 5th, 2009, 10:23pm Dear all, What is the reason (and difference in processing steps) that older technologies had pMOS devices with n+ polysilicon gates (buried channel) while newer technologies use pMOS with p+ polysilicon gates? Thanks! |
Title: Re: n+ polysilicon gates Post by vivkr on Jan 6th, 2009, 2:05am Hi Berti, The older technologies has thicker poly for the gate. Supposedly, this made harder to use implant techniques to dope them, and so they were doped during the poly deposition process, and so all were the same type (n+). With newer processes, it became possible to dope the thinner poly with implant and anneal methods. Just Googled on buried channel pmos, and found the info on this link: http://ece.iisc.ernet.in/~navakant/E3-238/lecture13.pdf Regards, Vivek |
Title: Re: n+ polysilicon gates Post by Berti on Jan 6th, 2009, 3:44am Thank a lot. So far I understand. But what is the motivation that buried channels are avoided in newer technologies? Is it the counter-doping required for PMOS with p+ polysilicon gates? Cost or mobility? Regards |
Title: Re: n+ polysilicon gates Post by vivkr on Jan 6th, 2009, 11:30pm Hi Berti, If you look at the link I sent in the earlier post, you will see the reason. In short, the counter doping which leads to formation of buried channels was an extra step which was necessary in the older technologies to achieve a reasonable (small) level of threshold voltage. This was due to the flatband voltage which results when using an n+ poly-Si gate for a PMOS. In the new processes where it is possible to have a p+ gate for PMOS, the flatband voltage is much better and there is no need for the extra step which was responsible for buried channel formation in PMOS. In fact, I doubt if you could actually achieve anything with counter doping anymore. It was the large amount of counterdoping required in older processes which led to formation of buried channels. So, it is not that the modern processes avoid buried channels per se, but more that the older processes could produce nothing but buried channels due to the use of an n+ gate for both PMOS and NMOS. Regards, Vivek |
Title: Re: n+ polysilicon gates Post by vivkr on Jan 7th, 2009, 4:31am Hi Berti, One interesting thing seems to be the argument behind why it was not possible to get anything but only n+ gates earlier for both PMOS and NMOS. The argument that the thicker poly could not be doped well with implant techniques is not quite clear. Maybe someone else can tell us why it was not possible to dope thicker poly gates with implant and anneal methods like we do nowadays. Perhaps there was a change in the way the poly was deposited also. Anyone??? Regards, Vivek |
Title: Re: n+ polysilicon gates Post by Maks on Jan 23rd, 2009, 12:25pm Berti - buried channel devices are avoided in modern technologies due to poor short-channel effects (as compared to surface channel devices), caused by 2D electrostatics. This was not an issue in old technologies with long channel/gate lengths, where short channel effects were non-existent. Buried channel devices have their own advantages - higher mobility (due to lower normal electric field and lower surface carrier scattering), lower noise (carriers are less interacting with traps/defects at the Si/SiO2 interface), lower NBTI degradation for pMOS, etc. Extra implant step for buried channel devices is not an issue - all modern MOSFETs have this extra implant step that is used to adjust Vt - threshold voltage. Maks ------------ |
Title: Re: n+ polysilicon gates Post by Tlaloc on Jan 27th, 2009, 8:14pm I also know that the n+ on the PMOS exacerbated DIBL effects as the channel lengths became smaller. Having the dual implants for the poly gates removed helped with that effect in the PMOS's |
