https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> PSS and Pnoise simulation for auto-zeroed SC integrator in Sigma-delta https://designers-guide.org/forum/YaBB.pl?num=1231850770 Message started by happyday on Jan 13th, 2009, 4:46am |
Title: PSS and Pnoise simulation for auto-zeroed SC integrator in Sigma-delta Post by happyday on Jan 13th, 2009, 4:46am Dear all, I have a question about using PSS and Pnosie to simulate an auto-zeroed SC integrator in sigma-delta modulator. I want to know the 1/f noise corner of an auto-zeroed SC integrator I have tried three different ways. All simulations are done with zero input and 5V clock signal. 1) SC integrator (with Cs and Cint), normal connection: Choosing noise type to "time domain", I can only plot output noise. Thus I need to divided it by the transfer function. Thus I simulated the PAC simulation, however I can not get the expected transfer function of the SC integrator. I use SC CMFB. If I change it to CT CMFB. I can get the PAC transfer function I want. 2) SC integrator (with Cs and Cint), close loop by adding an S&H to feedback the output of the integrator to the input during the next integration phase. This is described in Ken's paper about device noise simulation in Sigma-delta. Since it's a unity gain feedback, the output noise will equal to the input noise. PAC transfer function = 1 at low frequency 3) SC integrator (with Cs and Cint), normal connection, and then followed by a S&H, not close loop. This technique is described in Ken's paper about SC-filter. I only sample the point at the end of the integratotion phase. For these three techniques, I got different 1/f noise corner, I am not sure which one is the correct way to simulate the input inferred noise for auto-zeroed SC integrator. Is there anyone who knows about this problem? Thank you very much in advance and I appreciate it. |
Title: Re: PSS and Pnoise simulation for auto-zeroed SC integrator in Sigma-delta Post by happyday on Jan 19th, 2009, 4:30am Sorry that I did not explain the things clear. Here I upload some pdf files that explain the problem. the UGB of 1st opamp is 7 time the sampling frequency fs. fs = 40kHz. sampling capacitor cin = 3pF, integration capacitor cint = 12pF the integrator is using CDS (correlated double sampling) to reduce 1/f noise. SC_integrator.pdf shows the topology of the integrator noise_plot_not_close loop.pdf shows the "time domain" pnoise result of topology "SC_integrator.pdf" SC_integrator_closeloop_SH.pdf shows the close loop of the integrator by a sample & hold. noise_plot_closeloopSH.pdf shows the "time domain" pnoise result of topology "SC_integrator_closeloop_SH.pdf" |
Title: Re: PSS and Pnoise simulation for auto-zeroed SC integrator in Sigma-delta Post by happyday on Jan 19th, 2009, 4:31am pnoise plot of SC_integrator |
Title: Re: PSS and Pnoise simulation for auto-zeroed SC integrator in Sigma-delta Post by happyday on Jan 19th, 2009, 4:32am SC integrator close loop topology with sample & hold |
Title: Re: PSS and Pnoise simulation for auto-zeroed SC integrator in Sigma-delta Post by happyday on Jan 19th, 2009, 4:33am pnoise plot of SC integrator (close loop) with Sample & hold |
Title: Re: PSS and Pnoise simulation for auto-zeroed SC integrator in Sigma-delta Post by happyday on Jan 19th, 2009, 4:39am My questions are : 1/f noise corner is difficult in these two cases. How can I get a transfer function of the SC integrator? I can not get an expected transfer function of SC integrator (with opamp's DC gain at low frequency). Hope I make it clear now. Thank you in advance! |
Title: Re: PSS and Pnoise simulation for auto-zeroed SC integrator in Sigma-delta Post by ShaXia on Feb 8th, 2011, 1:20am Hi, I am also simulating the auto-zeroed SC integrator, and I have come up with similar results. To my greatest surprise is that the noise floor of open-loop simulation and closed-loop simulation are different. I also saw that in your simulation result: about 250 nV/sqrt(Hz) for the open loop simulation and about 600 nV/sqrt(Hz) for the closed loop simulation. For me, the noise floor of the two simulations are also different: 80 nV/sqrt(Hz) for open-loop and 275 nV/sqrt(Hz) for closed-loop. I am using 10 pF Cs and sampling at 5 Mhz. I wonder why this is the case. |
Title: Re: PSS and Pnoise simulation for auto-zeroed SC integrator in Sigma-delta Post by ShaXia on Feb 9th, 2011, 7:52am Now I get it: in the closed loop simulation I have to use "source" pnoise simulation, so that the calculation is still in frequency domain. The problem with doing time-domain pnoise simulation with close-loop is that the sampled noise comes back into the integrator input via the feedback path and gets amplified. That is why when I did close-loop time-domain simulation I get a much higher noise floor of the integrator. |
