https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> wreal bidirectionality - Any solution ? https://designers-guide.org/forum/YaBB.pl?num=1232118197 Message started by lusorg on Jan 16th, 2009, 7:03am |
Title: wreal bidirectionality - Any solution ? Post by lusorg on Jan 16th, 2009, 7:03am Hi all, I need model simple in/out block using wreal. It's is possible ? Because i cannot use Z to open connection. Thanks all. |
Title: Re: wreal bidirectionality - Any solution ? Post by jbdavid on Jan 16th, 2009, 3:08pm I know of no wreal implementation that supports that yet. Maybe you need to try some of the other ways of extending verilog. |
