https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> Differential noise figure measurements https://designers-guide.org/forum/YaBB.pl?num=1233236788 Message started by Oleksiy on Jan 29th, 2009, 5:46am |
Title: Differential noise figure measurements Post by Oleksiy on Jan 29th, 2009, 5:46am Hello! Can you recommend me some literature on differential noise figure measurement techniques? I need to measure differential LNA. Thank you. |
Title: Re: Differential noise figure measurements Post by pancho_hideboo on Jan 29th, 2009, 2:21pm Oleksiy wrote on Jan 29th, 2009, 5:46am:
There is a paper regarding a measurement of differential NF in IEEE JSSC. =============================================================================== TITLE: De-embedding the noise figure of differential amplifiers ISSUE: IEEE Journal of Solid-State Circuits, vol. 34, pp. 882 - 885, June 1999 AUTHORS: A. A. Abidi and J. C. Leete KEYWORDS: Amplifiers; Baluns; Cascade networks; Circuit noise; Differential amplifiers; Electric noise measurement; Losses; Measurement noise; Multiport networks; Noise measurement; Radiofrequency amplifiers BIBLIOGRAPHIC ENTRY: A. A. Abidi and J. C. Leete, "De-embedding the noise figure of differential amplifiers," IEEE Journal of Solid-State Circuits, vol. 34, pp. 882 - 885, June 1999. ------------------------------------------------------------------------------- ABSTRACT: Many radio-frequency circuits use differential topologies, whereas the instruments to evaluate them are inevitably single ended. Taking into account noise correlations, this work extends Friis' well-known equation for the noise figure of a cascade of two-ports to the case of three-ports, such as baluns, which surround a differential amplifier during measurements. The amplifier gain and noise figure may be accurately de-embedded with single-ended measurements on the cascade and on the baluns. The new formulas are experimentally validated. ------------------------------------------------------------------------------- REFERENCES: The links below are references to articles within the collection. Please refer to the paper itself for a full list of references. [1] Ahmadreza Rofougaran, James Y.-C. Chang, Maryam Rofougaran, Asad A. Abidi; A 1 GHz CMOS RF front-end IC for a direct-conversion wireless reciever, IEEE Journal of Solid-State Circuits, vol. 31, pp. 880 - 889, July 1996. [2] RF/IF Designer's Handbook, Mini-Circuits, Brooklyn, NY, pp. 2 - 2, 1992/1993. [3] RF and Microwave Designer's Handbook., Watkins-Johnson Co., Palo Alto, CA, p. 670, 1993-1994. [4] A. van der Ziel; Noise: Sources, Characterization, Measurement, Prentice-Hall, Englewood Cliffs, NJ, 1970. [5] R. Pettai; Noise in Receiving Systems, Wiley, New York, 1984. =============================================================================== But I don't use this method described in this paper since it is onerous. Instead I use two 180degree-Hybrid, here these two 180degree-Hybrid are included in a calibration of NF meter such as Agilent N8974A or N8975A Noise Figure Analyzer although this method might not be very accurate. Settings of Agilent N8975A Noise Figure Analyzer are like following. Pre Loss Compensation Mode is FIX Pre Loss Compensation Control is 1 Pre loss Compensation= 1.41[dB] Post Loss Compensation Mode is FIX Post Loss Compensation Control is 1 Post loss Compensation= 1.41[dB] Measurement ENR Table ID is "N4002A" |
Title: Re: Differential noise figure measurements Post by Oleksiy on Feb 4th, 2009, 4:36am Thank you pancho_hideboo! :) |
