https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> hspice and K28.5 pattern https://designers-guide.org/forum/YaBB.pl?num=1233666867 Message started by wwm101 on Feb 3rd, 2009, 5:14am |
Title: hspice and K28.5 pattern Post by wwm101 on Feb 3rd, 2009, 5:14am how to use K28.5 pattern in hspice simulation? thank you in advance. |
Title: Re: hspice and K28.5 pattern Post by Geoffrey_Coram on Feb 3rd, 2009, 6:34am Are you looking for an independent voltage source that generates a K28.5 pattern? Or do you have one, and you don't know how to use it in HSpice? (I had to Google K28.5 to even have any idea what you were talking about ... It's best not to assume that everyone here knows exactly what sorts of simulation you're doing.) |
Title: Re: hspice and K28.5 pattern Post by Andrew Beckett on Feb 3rd, 2009, 9:47pm I also had to google K28.5. I think you need something like this in HSPICE: Code:
This means 3V high, 0V low, 0n delay, 1n rise and fall time, 5n for each sample, and then the k28.5 pattern. The r=-1 means repeat indefinitely. This is assuming that I found the right pattern from my google searches... Spectre also has a similar bit source (see "spectre -h vsource" which can output bit sequences or reference named patterns). Regards, Andrew. |
Title: Re: hspice and K28.5 pattern Post by wwm101 on Feb 4th, 2009, 4:40am to:Andrew Beckett,Geoffrey_Coram thank you very much. |
