https://designers-guide.org/forum/YaBB.pl Modeling >> Passive Devices >> analoglib mtline usage ask for help!! https://designers-guide.org/forum/YaBB.pl?num=1233788466 Message started by cnnzhang2 on Feb 4th, 2009, 3:01pm |
Title: analoglib mtline usage ask for help!! Post by cnnzhang2 on Feb 4th, 2009, 3:01pm dear all, It is the first time I post here. I used mtline for t-line in spectre. I obtain s-parameter from hfss and then convert to RLGC and used with mtline for one line case, it is good. But when I tried to do the same thing for a diffrential line, I convert the 4-port s-paramter from hfss into mixed-mode s-parameter, and then convert them to mixed-mode RLGC, then I entered the following in the mtline RLGC entries: Rdd Rdc Rcd Rcc Ldd Ldc Lcd Lcc Gdd Gdc Gcd Gcc Cdd Cdc Ccd Ccc ("d" stands for differential-mode, "c" stands for common-mode) after starting SP simulation, there is this message: warning during spectre hierachy flattening warning (CMI-2114) defineQ:unit of quantity "Q" is changed from "coul" to "C" warning (CMI-2114) defineFreq:unit of quantity "F" is changed from "N" to "Hz" And it shows the SP satrts runing. Then the simulator just hangs there. Could anybody tell me what the problem may be and how I can solve it? I need differential line in spectre for S-parameter and transient simulation. Thank you very much. :'( |
