https://designers-guide.org/forum/YaBB.pl Simulators >> System Simulators >> Using Simulink to model a RF transceiver https://designers-guide.org/forum/YaBB.pl?num=1233929450 Message started by AnalogAroma on Feb 6th, 2009, 6:10am |
Title: Using Simulink to model a RF transceiver Post by AnalogAroma on Feb 6th, 2009, 6:10am Hi Everybody, I have been experiencing some problems to model a RF transceiver in Simulink. My baseband signal has a BW of 4MHz. But when I upconvert this signal at 1GHz , the shifted baseband signal spectrum seems very strange !! Any simulink expert available in this forum ? |
Title: Re: Using Simulink �to model a �RF transceiver Post by pancho_hideboo on Feb 6th, 2009, 7:17pm AnalogAroma wrote on Feb 6th, 2009, 6:10am:
Show me your block diagram of Simulink and resulting Spectrum. How to model upconverter in Simulink ? Just simply multiplier ? Or using Mixer in RF block set ? Which of model in the followings do you use ? (1)BB-Signal, I(t)+j*Q(t) ---> Real RF Signal, (I(t)+j*Q(t))*exp(j*omega0*t) (2)BB-Signal, I(t)+j*Q(t) ---> Equivalent Lowpass Representation of RF Signal, {I(t)+j*Q(t), omega0} What solver do you use in Simulink ? Continuous or Discrete ? What time step control do you use ? If you use (1), time step is enough small ? |
Title: Re: Using Simulink to model a RF transceiver Post by AnalogAroma on Feb 10th, 2009, 1:45pm Show me your block diagram of Simulink and resulting Spectrum. ------------ AA : Please see the attached file. A pdf file containing the spectrums will be added later. ------------------------------- How to model upconverter in Simulink ? Just simply multiplier ? Or using Mixer in RF block set ? ------------------------------------------ AA: I have used a multiplier. ---------------------------------------------- Which of model in the followings do you use ? (1)BB-Signal, I(t)+j*Q(t) ---> Real RF Signal, (I(t)+j*Q(t))*exp(j*omega0*t) (2)BB-Signal, I(t)+j*Q(t) ---> Equivalent Lowpass Representation of RF Signal, {I(t)+j*Q(t), omega0} -------------------------------------- AA: Method 1 , real RF signal. ------------------------------------ What solver do you use in Simulink ? Continuous or Discrete ? ------------------------------------- AA : Discrete ------------------------------------- What time step control do you use ? If you use (1), time step is enough small ? ------------------------------------ AA : Variable time step. Max time step is auto. I have also used 10 ps , but no improvement ! |
Title: Re: Using Simulink to model a RF transceiver Post by AnalogAroma on Feb 10th, 2009, 1:48pm pancho_hideboo wrote on Feb 6th, 2009, 7:17pm:
The signal spectrums are shown in the attached pdf file. |
Title: Re: Using Simulink �to model a �RF transceiver Post by pancho_hideboo on Feb 12th, 2009, 7:16am Maybe due to rate mismatch between BB and LO signals. Insert upsampler for BB or set upsample ratio in raised cosine filter. If you upload your block dirgram, I can modify. |
Title: Re: Using Simulink to model a RF transceiver Post by AnalogAroma on Feb 12th, 2009, 7:26am Thanks a lot for your kind feedback. The zipped Simulink model is attached herewith. |
Title: Re: Using Simulink �to model a �RF transceiver Post by pancho_hideboo on Feb 13th, 2009, 8:58am Frame time lengths before mixer are different in your setting while you use frame-based sampling mode. |
Title: Re: Using Simulink �to model a �RF transceiver Post by pancho_hideboo on Feb 13th, 2009, 8:59am This is my setting. |
Title: Re: Using Simulink �to model a �RF transceiver Post by pancho_hideboo on Feb 13th, 2009, 9:04am These are results of spectrum. Why do you set LO frequency as 1GHz ? In simulink model, you don't have to set LO frequency as real frequency. So you should use Equivalent Lowpass Representation of RF Signal or low frequency as LO. �BB-Signal, I(t)+j*Q(t) ---> Equivalent Lowpass Representation of RF Signal, {I(t)+j*Q(t), omega0} |
Title: Re: Using Simulink �to model a �RF transceiver Post by AnalogAroma on Feb 14th, 2009, 3:33am Wow ! Your simulation results look fantastic. I want to use your settings to do simulate the transeiver in my office computer. But from the last Thursday evening, I have been sick and will not go to the office for several days. After my recovery, I will post my replies again. |
Title: Re: Using Simulink to model a RF transceiver Post by AnalogAroma on Mar 11th, 2009, 8:46am Hi PH, I am back from the hospital. After following your setting , I have got properly upconverted spectrum. Howerver, I can not zoom the spectrum. I have played with several options, but the spectrum resolution is not as good as yours. Which setting have you used in the fft plot ? May I have a look and run you Simulink file on my side ? |
Title: Re: Using Simulink �to model a �RF transceiver Post by pancho_hideboo on Mar 13th, 2009, 8:10am AnalogAroma wrote on Mar 11th, 2009, 8:46am:
See attached model of Simulink. |
Title: Re: Using Simulink to model a RF transceiver Post by AnalogAroma on Mar 13th, 2009, 3:34pm Hi Pancho_hideboo, After applying your Spectrum scope settings , I have got really cool spectrums !! Now , modelling in Simulink seems to be enjoyable. Thanks a lot to dispel my initial frustration with Simulink ! |
