https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> How to balance I/Q loading for CML divider? https://designers-guide.org/forum/YaBB.pl?num=1235699494 Message started by jlee on Feb 26th, 2009, 5:51pm |
Title: How to balance I/Q loading for CML divider? Post by jlee on Feb 26th, 2009, 5:51pm Hi guys, As the title, a CML divider(DIV-1) is used to generate a group of I/Q differential signals (In, Ip, Qn, Qp) for the following mixer. Since there is another CML divider(DIV-2) following this divider(DIV-1), which means a group of differential signals will be fed into DIV-2, the I/Q loading for DIV-1 will not be balance. Is there any suggestion or paper as reference to solve this problem? Thanks in advance! Regards :D |
Title: Re: How to balance I/Q loading for CML divider? Post by mydreamhouse on Feb 27th, 2009, 9:19am Capacitor compensation |
Title: Re: How to balance I/Q loading for CML divider? Post by ywguo on Mar 4th, 2009, 8:01pm jlee, Now that one pair of differential signals goes to DIV-2, put a dummy DIV-2 for the other pair of differential signals. Yawei |
