https://designers-guide.org/forum/YaBB.pl Design >> High-Power Design >> how to make a soft-start in charge pump https://designers-guide.org/forum/YaBB.pl?num=1235812674 Message started by hdqkwr on Feb 28th, 2009, 1:17am |
Title: how to make a soft-start in charge pump Post by hdqkwr on Feb 28th, 2009, 1:17am Hi,all: In a charge pump DC-DC converter, how to make a soft-start in it?As in start up time, there is large inrush current exist in charge pump.I want to get some way to suppress it, is there any reference or any suggestion? |
Title: Re: how to make a soft-start in charge pump Post by NiceFeng on Apr 12th, 2009, 5:11am hdqkwr wrote on Feb 28th, 2009, 1:17am:
Hi,hdqkwr, During start-up period, you could operate some of the power switches as current source, which means connected the gate voltage to a biasing voltage instead of Vdd/GND. Feng |
Title: Re: how to make a soft-start in charge pump Post by mengcy on Mar 18th, 2010, 7:15pm Hi, do you integrate a short circuit protection or current limiting block on your chip? If the answer is yes, you can reuse the protection circuit to control the startup current. |
Title: Re: how to make a soft-start in charge pump Post by RobG on Feb 22nd, 2011, 12:00pm NiceFeng wrote on Apr 12th, 2009, 5:11am:
This is easy to do... see Fig. 12 of Gregoire, "A compact switched-capacitor regulated charge pump power supply," JSSC, Aug 2006, 1944-1953 |
Title: Re: how to make a soft-start in charge pump Post by Kevin Aylward on Jul 6th, 2013, 8:35am Large RC time constant on the reference voltage to the converter. |
