https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> a question about corner simulation https://designers-guide.org/forum/YaBB.pl?num=1236610019 Message started by Lilylily on Mar 9th, 2009, 7:46am |
Title: a question about corner simulation Post by Lilylily on Mar 9th, 2009, 7:46am During corner simulation,what does "fast nmos" or "fast pmos" mean? If I set the section of mos "the ff",must I set the sections of bjt,res,cap and other devices "the ff" simultaneously? Thanks! |
Title: Re: a question about corner simulation Post by raja.cedt on Mar 9th, 2009, 8:09am hi, i feel it depends strongly on the circuit.Lets say if you are using poly resistor it is independent on process,so in this case for any thing more or less you will get same result,whereas some circuits like biasing,less resistor value may gives worst condition.If you are not in a position to decide worst corner,do both simulations(fast nmos,less res and fast nmos ,high res). Thank you, Rajasekhar. |
