https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> dynamic range https://designers-guide.org/forum/YaBB.pl?num=1236669861 Message started by anil reddy on Mar 10th, 2009, 12:24am |
Title: dynamic range Post by anil reddy on Mar 10th, 2009, 12:24am hi! everyone.. what is the def. of dynamic range? is it the ratio of max o/p swing to min.o/p swing? any comments on that... thank u.. |
Title: Re: dynamic range Post by raja.cedt on Mar 10th, 2009, 3:27am hi, dynamic range is the ration of signal power by noise power,in some some sense your def also seems correct,.but use this.U can get same from google. Thank you, Rajasekhar. |
Title: Re: dynamic range Post by Sarig on Mar 10th, 2009, 1:34pm Max Signal / Noise floor [ At each Freq.] or Max Singal / integrated input refered noise (rms) |
