https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> coordinate information of nodes in extracted view https://designers-guide.org/forum/YaBB.pl?num=1237282392 Message started by sugar on Mar 17th, 2009, 2:33am |
Title: coordinate information of nodes in extracted view Post by sugar on Mar 17th, 2009, 2:33am Hi, I believe coordinate information of nodes in extracted view by assura is save in somewhere. For example, in input.scs file, there is a node named _794_X_VDDA, I want to know its coordinate in layout. Does anyone know where I can find that? Thanks, River |
Title: Re: coordinate information of nodes in extracted view Post by Andrew Beckett on Mar 22nd, 2009, 11:49pm It's in the database itself - you can find the figures on the net object. If you don't want to know about SKILL, you should be able to use the Assura menus to probe a net by name - and then be able to zoom to that net. Have you tried that? Regards, Andrew. |
