https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> NCSIM in Cadence https://designers-guide.org/forum/YaBB.pl?num=1237805428 Message started by Prateek on Mar 23rd, 2009, 3:50am |
Title: NCSIM in Cadence Post by Prateek on Mar 23rd, 2009, 3:50am hi, we have cadence in our college, but ncsim doesnt work on it, are there different versions of cadence, where on some there is nc sim installed and on some it is not. If yes, can i still simulate verilog-ams file on it? and how please answer.... :) it will be very helpful |
Title: Re: NCSIM in Cadence Post by Andrew Beckett on Mar 23rd, 2009, 10:07am Verilog-AMS models are simulated using AMS Designer, which is included in the "IUS" stream of software (called "LDV" in earlier versions). The simulator is invoked using ncsim (often launched from either ADE, or from the hierarchy editor plugin within Virtuoso, or from the command line). If you want to use a Cadence mixed-signal simulator that supports Verilog-AMS, you'll need AMS Designer, and so you'll need access to "ncsim". Regards, Andrew. |
Title: Re: NCSIM in Cadence Post by Geoffrey_Coram on Mar 26th, 2009, 6:09am Are you using any AMS features? You can run Verilog-A models in Spectre, without AMS Designer or ncsim. |
