https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> a problem using AMS https://designers-guide.org/forum/YaBB.pl?num=1238306675 Message started by Ken Wong on Mar 28th, 2009, 11:04pm |
Title: a problem using AMS Post by Ken Wong on Mar 28th, 2009, 11:04pm Hi all, I am using AMS simulator to tset a verilog-coded bolock in spectre. After I set up the config, I choose "Mixed-Signal>>Interface Element>>Instance" for a2d and d2a setting, but it just reply "please select an instance to update". How can I solve the problem. thanks a lot. |
Title: Re: a problem using AMS Post by Andrew Beckett on Mar 30th, 2009, 9:20am The mixed signal menu is for the older SpectreVerilog simulator interface; it is NOT for AMS Designer. For AMS Designer, you control the connectmodule (interface elements are instances of connectmodules) by altering connect rules via the Setup->Connect Modules in the ADE window (assuming you're simulating via ADE), and then use the AMS->Default Discipline Selection if you need to specify a particular discipline for parts of the design. If you really need to that is... It sounds as if you're getting the two mixed signal simulators mixed up? (apologies for the dreadful pun there...) Regards, Andrew. |
