https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Reduction and https://designers-guide.org/forum/YaBB.pl?num=1238688183 Message started by neoflash on Apr 2nd, 2009, 8:03am |
Title: Reduction and Post by neoflash on Apr 2nd, 2009, 8:03am what is the definition of "reduction and" (&) in verilog ams? thanks. |
Title: Re: Reduction and Post by Geoffrey_Coram on Apr 3rd, 2009, 2:59am It's a bitwise operator. See section 4.2.9 of the Verilog-AMS LRM, version 2.3 Did you have a specific question about how it handles signed vs unsigned or unequal bit length arguments? |
Title: Re: Reduction and Post by neoflash on Apr 3rd, 2009, 5:07am Thanks. Just a little confused with what "reduction" refers to? |
Title: Re: Reduction and Post by Ken Kundert on Apr 3rd, 2009, 8:42pm Reduction & is applied to one argument and returns the logical and of all the bits in that argument. So it always returns a single boolean value. This contrasts to the bitwise & that applies to two bit vectors, and return a bit vector where each bit is the logical and of the corresponding bits in the arguments. So if A is 2'b11 and B is 2'b01, then &A is 1, &B is 0, and A&B is 2'b10. The first two are reduction &, the last is bitwise &. -Ken |
Title: Re: Reduction and Post by Geoffrey_Coram on Apr 6th, 2009, 4:33am Oops, sorry, I was completely wrong. I should have pointed you to 4.2.10 Reduction operators The reduction operators can not be used inside the analog block and only have meaning when used in the digital context. Information on these operators can also be found in the IEEE std 1364-2005 Verilog HDL. -- or you can just read Ken's post. |
