https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> default model library in ADE https://designers-guide.org/forum/YaBB.pl?num=1238792751 Message started by analogue_guy on Apr 3rd, 2009, 2:05pm |
Title: default model library in ADE Post by analogue_guy on Apr 3rd, 2009, 2:05pm Hi, Do you know how can I set the default model library in ADE? Or which setting option or whatever does it depend? cheers, |
Title: Re: default model library in ADE Post by oermens on Apr 3rd, 2009, 3:57pm add/modify your .cdsenv with the following: spectre.envOpts modelFiles string "/path_to_your_model_file/model_file.scs" spectre.envOpts includePath string "/path_to_your_model_file/" |
