https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> hspicerf simulation https://designers-guide.org/forum/YaBB.pl?num=1239610689 Message started by zhengzheng08 on Apr 13th, 2009, 1:18am |
Title: hspicerf simulation Post by zhengzheng08 on Apr 13th, 2009, 1:18am when i do a hspicerf simulation ,it reports errors as follows: "~~resistor.lib incompleted input for .param statement" whether it means that the lib losts something for rf simulation? because when i use the same lib do hspice simulation for the same design ,it runs without errors. who can tell me what's wrong with my simulation ,thankyou very much~~~~ :-[ |
Title: Re: hspicerf simulation Post by spiceoracle on Apr 13th, 2009, 11:05am In the resistor.lib file, look for any .param statements that have continued lines using the double backslash characters (\\). If the .param statment has the parameter name separated from the first portion of the parameter definition, then this is the problem. For example: .param long_exp = \\ '((a+b)/(c*d) + \\ (v(out)*scale)' The work around is to write the .param statment as: .param long_exp = '((a+b)/(c*d) + \\ (v(out)*scale)' This is a know problem and is fixed in the C-2009.03 version of HSPICE RF. |
