https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> what is the OSS/irun flow in AMS in ADE https://designers-guide.org/forum/YaBB.pl?num=1239782538 Message started by idriss on Apr 15th, 2009, 1:02am |
Title: what is the OSS/irun flow in AMS in ADE Post by idriss on Apr 15th, 2009, 1:02am Hi guys, do you know guys what is the OSS/irun flow in AMS in ADE and how it can be used. regards idris |
Title: Re: what is the OSS/irun flow in AMS in ADE Post by Andrew Beckett on Apr 15th, 2009, 3:06am Simulation->Netlister and Run Options - then pick OSS/irun. Look at <ICinstDir>/doc/AMSinADEFAQ/AMSinADEFAQ.pdf - you may need to be using a recent IC5141 Hotfix to have this doc though (it should also be on sourcelink.cadence.com ) Regards, Andrew. |
