https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to plot OP parameter with sweep variable in Spectre? https://designers-guide.org/forum/YaBB.pl?num=1239886821 Message started by Yutao Liu on Apr 16th, 2009, 5:00am |
Title: How to plot OP parameter with sweep variable in Spectre? Post by Yutao Liu on Apr 16th, 2009, 5:00am Hello everyone, I want to plot some parameters of operating point versus the variable that is swept in DC simulation. And my method is setting dc analysis and running parametric analysis with a variable the same as the one swept in dc, and plot the wave with "result browser". Is my method ok? And is there any other better ways to do it? thanks a lot! |
Title: Re: How to plot OP parameter with sweep variable in Spectre? Post by holddreams on Apr 16th, 2009, 5:43am You can use spectremdl to realize it. |
Title: Re: How to plot OP parameter with sweep variable in Spectre? Post by Andrew Beckett on Apr 17th, 2009, 6:11am Or make sure that you have: save *:oppoint in your netlist (add this in an included "model file" if using ADE), and then do a normal DC sweep. This will save all operating point parameters for all (wildcarded) devices. This will be quicker than doing a parametric sweep. Regards, Andrew. |
