https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to make default settings in ADE? https://designers-guide.org/forum/YaBB.pl?num=1240503838 Message started by subgold on Apr 23rd, 2009, 9:23am |
Title: How to make default settings in ADE? Post by subgold on Apr 23rd, 2009, 9:23am im using cadence 5.10.41. i would like to save a default setup for my ADE, such as waveform tool, plotting mode, etc. does anybody know how to do that? i know that is not critical for the design, but sometimes these trivia can become really annoying.... |
Title: Re: How to make default settings in ADE? Post by Andrew Beckett on Apr 24th, 2009, 6:33am These are typically done with cdsenv settings. You can set things up the way you want, and then do Options->Save Defaults in the CIW. You may want to edit the file afterwards to just keep the settings you really want to set - the names are normally pretty obvious. For example, the ~/.cdsenv to set "wavescan" as the default (it's the default anyway) is: Code:
Regards, Andrew |
Title: Re: How to make default settings in ADE? Post by subgold on Apr 27th, 2009, 1:30pm Andrew Beckett wrote on Apr 24th, 2009, 6:33am:
thank you very much! |
