https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Clock state https://designers-guide.org/forum/YaBB.pl?num=1240763174 Message started by nishant22 on Apr 26th, 2009, 9:26am |
Title: Clock state Post by nishant22 on Apr 26th, 2009, 9:26am Hi I am writing Verilog A model for a block which has 2 clocks coming as inputs, both may have different frequency. I have to check if during the simulation any of the clock dissapears or is stopped, my output should go to zero. How can I model this? And it should detect that when both clocks come back again and execute rest of my model. Its really important. Thanks, Nishant |
Title: Re: Clock state Post by Peruzzi on Apr 27th, 2009, 8:30am Hello Nishant, You can devise an algorithm to do this. For each clock. For each rising edge detection, find the difference between the present time and the time of the previous rising edge and the frequency is the reciprocal of that difference. If the frequency is within tolerance, set some status variable indicating OK, and set up a timer() function to return execute some time in the future, corresponding to your definition of "if during the simulation any of the clock dissapears or is stopped". Do a similar thing when the timer() executes to make sure the clock frequency is still OK. You have to mess around with it a little to get it right, but I'm sure this is enough to get you going. You get the idea, right? You can also google around for "loss of clock detection". Bob P. www.RPeruzzi.com |
