Other CAD Tools >> Entry Tools >> How to know current origin in Cadence Virtuoso Symbol Editor ?
https://designers-guide.org/forum/YaBB.pl?num=1241258651
Message started by pancho_hideboo on May 2nd, 2009, 2:04am
Title: How to know current origin in Cadence Virtuoso Symbol Editor ?
Post by pancho_hideboo on May 2nd, 2009, 2:04am
I can set an origin in Virtuoso Symbol Editor.
However I can't find a method to know where current origin is located.
Any expert of Cadence Tools, teach me.
Title: Re: How to know current origin in Cadence Virtuoso Symbol Editor ?
Post by Andrew Beckett on Jul 10th, 2009, 7:45am
Pancho,
Sorry about the delay. Been a tad busy the last few weeks.
Anyway, in the Symbol Editor go to Options->Display and turn on "Coordinates on Status Banner".
You'll then see the coordinates as you move your cursor. 0,0 is the origin.
You can do Edit->Origin to move the origin (actually everything moves if you do this).
Best Regards,
Andrew.
Post by pancho_hideboo on Nov 24th, 2009, 3:32am
By setting "Schematics > Options > Display : Coordinates_on_Status_Banner" as "on" manually, I can show coordinate information in Symbol Editor.
However I would like to this as default setting.
So I write the following in ".cdsinit".
� � envSetVal( "schematic" "statusBannerXY" 'boolean t )
But this does not work.
Maybe kewords such as "schematic" and "statusBannerXY" are improper.
How should I write to set "Schematics > Options > Display : Coordinates_on_Status_Banner" as "on".
Post by oermens on Nov 24th, 2009, 5:31am
In your .cdsenv try adding the following:
schematic      statusBanner      boolean      t
schematic      statusBannerXY      boolean      t
Post by pancho_hideboo on Nov 24th, 2009, 5:37am
oermens wrote on Nov 24th, 2009, 5:31am:
I don't use ".cdsenv".
I already have the following in ".cdsinit".
I will try add the following in ".cdsinit".
� envSetVal( "schematic" "statusBanner" 'boolean t )
Post by pancho_hideboo on Nov 27th, 2009, 2:12am
This is for "Display Status Banner=on".
So even if I set following two, still I can't set "Schematics > Options > Display : Coordinates_on_Status_Banner" as "on".
Post by Andrew Beckett on Jan 4th, 2010, 9:13am
Pancho Hideboo,
You have to use the function:
schChangeStatusBanner("xy")
I suspect this is for some strange historical reason - probably predating cdsenv settings...
It seems that the form sets the cdsenv setting based on which banner is in place (the other value is "default").
Ah, I found a CCR about this, asking for this to be made public - CCR 78112 - and it seems the original reason was for performance - it was expensive to have to keep consulting the cdsenv setting (even in memory) every time the cursor was moved.
Apparently it does work if you use a .cdsenv file (I didn't check), and so this workaround SKILL function is only needed if you want to do it via SKILL rather than via a .cdsenv file.
Regards,
Andrew.
Post by pancho_hideboo on Jan 7th, 2010, 1:46am
Andrew Beckett wrote on Jan 4th, 2010, 9:13am:
Thanks.
schChangeStatusBanner() can work
as schChangeStatusBanner("xy") for "on",
and as schChangeStatusBanner("") for "off".
