https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> inductor extraction https://designers-guide.org/forum/YaBB.pl?num=1241607867 Message started by analog_cha on May 6th, 2009, 4:04am |
Title: inductor extraction Post by analog_cha on May 6th, 2009, 4:04am Hi If i want to see the magnetic filed effects(like eddy currents) of the spiral into the substrate using assura, can it be possible?? Say an inductor's layout is done with pattern ground shielding. How can i estract it to account for the magnetic field effects also in my extracted view??? Thanks. |
