https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Input impedance https://designers-guide.org/forum/YaBB.pl?num=1241731879 Message started by analogue_guy on May 7th, 2009, 2:31pm |
Title: Input impedance Post by analogue_guy on May 7th, 2009, 2:31pm Hi, What kind of analysis and methodology are you using to simulate input impedance of non-linear circuitry? Cheers, --AG |
Title: Re: Input impedance Post by pancho_hideboo on May 8th, 2009, 11:35pm analogue_guy wrote on May 7th, 2009, 2:31pm:
Title: Re: Input impedance Post by analogue_guy on May 11th, 2009, 12:26pm Hi, Basically let us say I have a circuit which input impedance varies with the input current and I would like to have the dependence of the input impedance of the input current. How am I doing now? I basically apply an ipwl source and I sweep the current from 0 to the maximum level of interest and at some certain points I run ac simulations, collecting the data and from these data I calculate back the parallel RC equivalents. i was interested in, if there is a better or easier way to do that? or you can see any problem with that methodology regards |
Title: Re: Input impedance Post by cmos.analogvala on May 11th, 2009, 7:24pm I think this is the method. Two more things you can add in the existing simulation setup are 1) parametric simulations and 2) save expression in ADE if you are using cadence/Spectre. 1) Make dc value of your input current design variable. Vary that in parametric. 2) Use calculator to give you Rin at some frequency and save the expression. The simulator will give you the plot of Rin vs parameter value. CA |
Title: Re: Input impedance Post by analogue_guy on May 13th, 2009, 7:46am cmos.analogvala wrote on May 11th, 2009, 7:24pm:
Hi, Thanks for your advices, it seems together with DC sweep maybe I could use the captab option to extract the capacitance. Cheers |
