https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Does anyone know a chip with integrated Mixer and PLL (UHF band) https://designers-guide.org/forum/YaBB.pl?num=1242115163 Message started by Mauro Borgo on May 12th, 2009, 12:59am |
Title: Does anyone know a chip with integrated Mixer and PLL (UHF band) Post by Mauro Borgo on May 12th, 2009, 12:59am I've found the old Zarlink SL2101, but it seems ther is no replacement of such a chip. RFMD produce the RF2053, however the price seems to be quite high. Do you know of other similar products ? |
Title: Re: Does anyone know a chip with integrated Mixer and PLL (UHF band) Post by loose-electron on May 16th, 2009, 4:48pm define the problem with a lot more detail please - sound like you have a components question. |
Title: Re: Does anyone know a chip with integrated Mixer and PLL (UHF band) Post by Mauro Borgo on May 18th, 2009, 12:26am loose-electron wrote on May 16th, 2009, 4:48pm:
Yes, it is a component question. Hoping to have posted the question in the right place. In order to simplify the design of a multiple frequency converter in the 200-1400 MHz band. I'd like to have a single chip with a mixer and a PLL integrated in it. I've found an obsolete chip by zarlink (SL2101). My question is: exist something similar by other producer ? In alternative I must use the classic configuration with separated elements: vco, PLL, and mixer. Even in this case, someone can suggest some (low price) components ? Thank you. |
Title: Re: Does anyone know a chip with integrated Mixer and PLL (UHF band) Post by loose-electron on Jun 18th, 2009, 6:33pm suggest that you specify what you want as completly as possible, and then start putting inquiries out to the various semiconductor shops that sell RF IC's Its called doing research... ::) |
