https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> bmslib in cadence university suite https://designers-guide.org/forum/YaBB.pl?num=1243060520 Message started by cmos.analogvala on May 22nd, 2009, 11:35pm |
Title: bmslib in cadence university suite Post by cmos.analogvala on May 22nd, 2009, 11:35pm We do not have "bmslib" library with the present cadence icfb(IC5141) tool set. I think bmslib is a powerful lirary for measurements similar to analogLib for sources and basic components ? We have cadence university package with us. The questions are: Is my understanding about cadence bmslib correct ? How to get bmslib in cadence university package ? Please reply Thanks -CA |
Title: Re: bmslib in cadence university suite Post by Andrew Beckett on May 29th, 2009, 1:05am Really? It's installed whenever spectre is installed as part of the IC5141 products (product 32500, 32520 or 90001). So I'd be very surprised if its not there. It should be in <ICinstDir>/tools/dfII/samples/artist/bmslib Regards, Andrew. |
Title: Re: bmslib in cadence university suite Post by cmos.analogvala on May 29th, 2009, 11:47pm Thanks a lot ..BMSlib is present in the above mentioned location... When do we use ahdl lib and when do we use bmslib ? Thanks -CA |
Title: Re: bmslib in cadence university suite Post by Andrew Beckett on Jul 10th, 2009, 6:37am Which library to use depends on what model you want! These are sample model libraries, the idea is you can take your pick. You can use both if you like, or copy models from either library into your own, and modify them. Andrew. |
