https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> MonteExpr and Histogram in Ocean https://designers-guide.org/forum/YaBB.pl?num=1243938929 Message started by Leila on Jun 2nd, 2009, 3:35am |
Title: MonteExpr and Histogram in Ocean Post by Leila on Jun 2nd, 2009, 3:35am Hi all, I have tried to plot a histogram for delay in a simple inverter after running the monte carlo trans in scs file, I start running my script in ocean to view the histogram results by using: MonteExpr("delay" 'delay(?wf1 in ?value1 0.6 ?nth1 5 ?edge1 'rising ?wf2 out ?value2 0.6 ?nth2 5 ?edge2 'falling)) histogram("delay" ?numBins 100 ?density t) but apparently something is wrong and I can not see the histogram, let me tell you about the warning messages Monte carlo results has not been selected or invalid. Please advice to help me to sort this issue. :-/ Thanks Leila |
Title: Re: MonteExpr and Histogram in Ocean Post by Mohammed Omar on Jun 13th, 2009, 1:04pm Hi Leila, I guess you need to add the following line before evaluating the expressions monteSelectResults() Regards, Mohammed Omar |
