https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> gain expression for PAC analysis in ADE https://designers-guide.org/forum/YaBB.pl?num=1245683099 Message started by aNaloG_y on Jun 22nd, 2009, 8:04am |
Title: gain expression for PAC analysis in ADE Post by aNaloG_y on Jun 22nd, 2009, 8:04am Hello All, Does anyone know how to put output gain expression in cadence ADE for PAC analysis.? At present I am will plotting it once the PAC analysis is over by selecting the PAC results,but I want to put expression before analysis similar to AC analysis Regards, aNaLog_y |
Title: Re: gain expression for PAC analysis in ADE Post by pancho_hideboo on Jun 22nd, 2009, 8:27am aNaloG_y wrote on Jun 22nd, 2009, 8:04am:
Title: Re: gain expression for PAC analysis in ADE Post by aNaloG_y on Jun 22nd, 2009, 8:40am Hi pancho_hideboo, In AC analyis if you write gain expression in ADE e.g 20*db20("VT(/<netname>"),this expression will be plotted at the end of AC analysis. But in PAC,once run is over I need to go and select the PAC results and then plot the gain expression using calculator. Regards Ramesh |
Title: Re: gain expression for PAC analysis in ADE Post by pancho_hideboo on Jun 22nd, 2009, 8:54am aNaloG_y wrote on Jun 22nd, 2009, 8:40am:
Choose "ADE>Results>Direct Plot" for both ac and pac with "Add Outputs=On". Or use result browser for both ac and pac. Then invoke calculator and do "get expression". In anyway, you can get following expressions in output field. db20( v("/<netname>" ?result "ac-ac") ) db20( v("/<netname>" ?result "pac-pac") ) |
