https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Reference for I-/Q-channel ADC https://designers-guide.org/forum/YaBB.pl?num=1246458047 Message started by Berti on Jul 1st, 2009, 7:20am |
Title: Reference for I-/Q-channel ADC Post by Berti on Jul 1st, 2009, 7:20am Hi all, I have two (I- and Q-channel) delta-sigma ADCs for cellular, each with his own reference voltage buffer. I am wondering whether it makes sense to share the buffer (thereby minimizing mismatch on the voltage reference which increases image rejection etc.) or is this a bad idea because of cross-talk between the two channels? Regards |
Title: Re: Reference for I-/Q-channel ADC Post by jbdavid on Jul 16th, 2009, 6:09pm If I were a design lead, I wouldn't accept your decision based just on an answer from this forum.. I'd spend an hour with you just reviewing how you modeled the potential interaction, and looking over the simulation results on which you based your decision.. Its the kind of thing good designers write papers about.. jbd |
Title: Re: Reference for I-/Q-channel ADC Post by Berti on Jul 21st, 2009, 11:02pm Quote:
I agree, but it is always good to collect some other opinions .... |
Title: Re: Reference for I-/Q-channel ADC Post by wave3x on Aug 18th, 2009, 11:14pm I think IQ ADC need not to use independent reference driver, just to simplify the design and layout. Cross-talk will not be a big issue. image rejection also be a less significant issue just if you pain a little attention about it. Of course I assume your system does not need a IR < -50dB. Berti wrote on Jul 1st, 2009, 7:20am:
