https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> Rnwell Assura LVS issue https://designers-guide.org/forum/YaBB.pl?num=1246507466 Message started by Rwalker on Jul 1st, 2009, 9:04pm |
Title: Rnwell Assura LVS issue Post by Rwalker on Jul 1st, 2009, 9:04pm I get funny LVS errors when using rnwell pcells from my pdk: ntap connected to GROUND ! (some of my nwell resistors terminate at gnd) floating nxwell is not allowed (I see this for series segments of my R that are not the top/bottom segments) I tried applying the HOTWL layer but still see these errors. |
Title: Re: Rnwell Assura LVS issue Post by Andrew Beckett on Jul 10th, 2009, 9:06am You're more likely to get a meaningful answer if you state what design kit or Assura Rules you're using. Without knowing that, the messages could mean anything... Regards, Andrew. |
Title: Re: Rnwell Assura LVS issue Post by rfeda on Nov 8th, 2009, 2:36pm The error message in your case seems to be an ERC error. The check "ntap connected to gnd" should normally be performed on any nwell that contains a p-mosfet" or an nwell forming an isolation ring of some sort. This check should be done to ensure no nwell/p-sub diode is forward biased. The resistor nwell should be precluded from this check. You could solve this issue by examining the generation of the "nwell" layer used to perform the ERC check. Modifying the generation of the nwell may stop these violations on the resistor nwell. Hope this helps. |
