https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> Problem with GNUPLOT https://designers-guide.org/forum/YaBB.pl?num=1247168059 Message started by buddypoor on Jul 9th, 2009, 12:34pm |
Title: Problem with GNUPLOT Post by buddypoor on Jul 9th, 2009, 12:34pm Hallo ! I have some problems with GNUPLOT to produce a specific 3-D-plot: I like to plot the classical EULER-relation f(x)=cos(x)+j*sin(x) with the following restrictions: x-axis (real)=cos(x), y-axis(imag)=sin(x), z-axis=f(x). As a result, there should be something like a helix in z-direction. Can anybody tell me how to scale the axes appropriately? Thank you and regards LvW |
Title: Re: Problem with GNUPLOT Post by Andrew Beckett on Jul 10th, 2009, 9:00am I'm not really that familiar with gnuplot, but I think there's an example which does just this on http://www.gnuplot.info/demo/surface2.html. I can't test it that easily as my gnuplot version is too old (and I don't want to bother trying to update it just to test something I'm unlikely to use...) Regards, Andrew. |
Title: Re: Problem with GNUPLOT Post by buddypoor on Jul 10th, 2009, 12:25pm Hi Andrew ! Thank you very much for your reply. It was a very valuable information. Thanks again . Regards LvW |
