Simulators >> Circuit Simulators >> cadence ADE error
https://designers-guide.org/forum/YaBB.pl?num=1248162466
Message started by anil reddy on Jul 20th, 2009, 11:47pm
Title: cadence ADE error
Post by anil reddy on Jul 20th, 2009, 11:47pm
hi all,
i am new to cadence ADE tool. when i simulate a simple cs stage with current source load it shows the error "input.scs :illegal parameter name specified". can anybody give the solution to rectify that?
thank you all.....
Title: Re: cadence ADE error
Post by qiushidaren on Jul 21st, 2009, 12:24am
The output log tells you where your error occures, check you use the right parameter unit, say, use lowercase u don't use uppercase U, hope that helps!
