https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Help with DDR LDO https://designers-guide.org/forum/YaBB.pl?num=1248180301 Message started by refugee on Jul 21st, 2009, 5:44am |
Title: Help with DDR LDO Post by refugee on Jul 21st, 2009, 5:44am My recent work is to design a LDO for DDR I II III. Now I meet some problems. Please give me some advise. The design aim is to design a LDO that can both sink and source current (+/- 10mA). The output voltage range is 0.75V ~ 1.25V, the output cap is 100nF (So, the output should set as the main pole), the output voltage accuracy is +/- 10mV Because the system could both source and sink current, So, I want to know how to design a circuit that control which loop turn on Thank you for your help |
Title: Re: Help with DDR LDO Post by ywguo on Sep 24th, 2009, 6:12pm Hi, It sounds like a DDR output driver, not like a LDO. :) Yawei |
Title: Re: Help with DDR LDO Post by raja.cedt on Sep 24th, 2009, 10:05pm hi, you have specifications with you right, then start fix loop gain based on settling and you have given accuracy 10mv now find open loop gain Thanks, Rajasekhar. |
Title: Re: Help with DDR LDO Post by loose-electron on Sep 29th, 2009, 11:12am This is not an LDO - its better known as an OTA (Operational Transconductance Amplifier) |
