https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> set logic to 0V at simulation start https://designers-guide.org/forum/YaBB.pl?num=1249919089 Message started by tempora123 on Aug 10th, 2009, 8:44am |
Title: set logic to 0V at simulation start Post by tempora123 on Aug 10th, 2009, 8:44am hello, I would like to run top level mixed signal (spectreVerilog) simulation where the power supply is ramped up from 0 to vdd. I need to reset all nodes inside the circuit to a known state because now I get unknown states for some internal nodes and spectre doesnt converge. Is there any switch (+sdf... or other way) I could use in the Simulation -> Options -> Digital tab to reset all nodes to 0V? Thanks for your help. |
