https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> A question about device noise simulation of sigma-delta modulators https://designers-guide.org/forum/YaBB.pl?num=1249960218 Message started by alixluohao on Aug 10th, 2009, 8:10pm |
Title: A question about device noise simulation of sigma-delta modulators Post by alixluohao on Aug 10th, 2009, 8:10pm Today I simulated the device noise of my swiched-capacitor sigma-delta modulator with the method using a ideal S/H to close the loop, as the designer's guide "Device Noise Simulation of sigma-delta modulators" said. The ideal S/H is implemented by Verilog-A as follows: module sah_ideal(vin, vout, vclk); input vin, vclk; electrical vin, vout, vclk; parameter real vtrans_clk = 1; real vout_val; analog begin @(cross(V(clk) - vtrans_clk, 1.0)) vout_val = V(vin); V(vout) <+ vout_val; end endmodule The tran simulation may be OK, but when implementing a PSS simulation, the "vout_val" is refered as a hidden state and the PSS simulation is terminated. How to eliminate the hidden state so as to apply the S/H to the device noise simulation? :'( Thanks! LUO |
Title: Re: A question about device noise simulation of sigma-delta modulators Post by currant on Aug 10th, 2009, 10:57pm Look this article about hidden-state free SH http://www.designers-guide.org/Analysis/hidden-state.pdf As I understand, it is impossible to simulate sigma-delta modulator by periodic analysis, because the output of modulator is not periodic, but chaotic. I've read about this in Spectre RF docs. Best regards. |
Title: Re: A question about device noise simulation of sigma-delta modulators Post by thechopper on Aug 11th, 2009, 5:37pm Hi LUO, Usually the noise performance of a sigma delta modulator is dominated by the first integrator. Try then to analyze the first integrator noise with PSS. In this case PSS will work and you will get a good idea of what your main input noise source will look like. Regards Tosei |
Title: Re: A question about device noise simulation of sigma-delta modulators Post by alixluohao on Aug 11th, 2009, 10:59pm Thank you for your suggestions. I will read the pdf "Hidden state in specreRF" and pay attention to the noise of the first intergrator. :) |
