https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Obtaining dynamic CPU time during Verilog execution https://designers-guide.org/forum/YaBB.pl?num=1250897244 Message started by cmolsen on Aug 21st, 2009, 4:27pm |
Title: Obtaining dynamic CPU time during Verilog execution Post by cmolsen on Aug 21st, 2009, 4:27pm I would like to obtain CPU time at any given point within Verilog code or at least on every entry/iteration of the VA code or on every converged iteration. The purpose of this is to debug runtime. To what extent is this possible? I can't find any Verilog functions that do this. So I'm guessing I may have to use the VPI to interface in a C program which accesses time and then passes it to the Verilog module. Assuming I have to go the VPI route, I have looked into this as follows: In the Accellera Verilog manual there's a VPI example which does something like what I want to do, namely the report_cpu() function. As a start I've tried implementing some very simple VPI function in C which only requires including vpi_user.h for say printing "vpi_printf("hello");". But VPI include files are nowhere to be found in my company's Spectre or Hspice install environments. Is VPI supposed to be bundled with a Spectre or Hspice install? Does it need to be activated? Or is this a separate install and if so, from where? Michael |
Title: Re: Obtaining dynamic CPU time during Verilog execution Post by Peruzzi on Aug 22nd, 2009, 10:00am Quick and dirty approach would be through waveform display. Show evaluation points as well as smoothed waveform. This may be enough for you to debug your situation. Bob P. |
Title: Re: Obtaining dynamic CPU time during Verilog execution Post by Sumit Adhikari on Aug 22nd, 2009, 8:19pm It should come with your basic installation and you dont need to do anything else. Just go to installation directory and type this command : find . -name "vpi*.h" I think you will be able to find the include path. If not report your tool vendor. BR, Sumit |
Title: Re: Obtaining dynamic CPU time during Verilog execution Post by Andrew Beckett on Aug 25th, 2009, 7:34am You can't use VPI with spectre, only with AMS Designer (ncsim). You can also use $debug() to output statements on every iteration, although I don't think you can output CPU time information. Regards, Andrew. |
