https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> Doubt about output units - PXF analysis in SpectreRF https://designers-guide.org/forum/YaBB.pl?num=1250901395 Message started by scv on Aug 21st, 2009, 5:36pm |
Title: Doubt about output units - PXF analysis in SpectreRF Post by scv on Aug 21st, 2009, 5:36pm I am trying to do a PSRR analysis of an LC_VCO using PXF analysis. I am following the procedures given in cadence app note 'Power Supply Rejection Ratio Characterization Using SpectreRF Autonomous Circuits'. When I plot the transfer from 'SSB' of input to 'PM' of output I get a graph with units in dB20(V/V). Is this a graph of 20 log * (Output Phase Change in Radians / Voltage Peak at Input). ie. Is the unit dB (radians/V)? or is it dB (degrees/Volt)? Because I dont understand how it can be V/V for a Phase modulated output vs a single side band input. Thanks. p.s. BTW, the final few pages of the app note specify the unit of phase to be in degrees. But I am just confused that the graph displays it as dB20(V/V) |
