https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> problems about filter solution v8.1 software https://designers-guide.org/forum/YaBB.pl?num=1252738156 Message started by baohulu on Sep 11th, 2009, 11:49pm |
Title: problems about filter solution v8.1 software Post by baohulu on Sep 11th, 2009, 11:49pm hi, all I use filter solution8.1 to synthesize a chebyshev II filter, which is in digital domain, for example, passband 1Hz, sampling clock 64Hz, and stopband ratio 1.5, then see its frequency response. as I know, its spectrum should be from -32Hz to +32Hz, when repeat it. however, in this software, its spectrum is from 0 to 64Hz, why? |
Title: Re: problems about filter solution v8.1 software Post by buddypoor on Sep 12th, 2009, 8:22am Because the program reflects reality ! There are no negative frequencies in reality ! It is only a mathematical "trick" to use neg. frequencies during formulation and calculation of the fourier transform (based on EULERīs formulas). As a result, you have 2 alternatives: spectrum from -x to +x with amplitudes A or from 0 to 2x with amplitudes 2A. |
Title: Re: problems about filter solution v8.1 software Post by Berti on Sep 15th, 2009, 2:40am SSB spectrum is the frequency from 0 to +x with 2x the amplitude (0..32Hz). Why should the frequency go up to 2x? Do I miss something? Cheers |
Title: Re: problems about filter solution v8.1 software Post by buddypoor on Sep 15th, 2009, 2:55am Berti wrote on Sep 15th, 2009, 2:40am:
No, Berti, you didnīt miss something. But I was wrong, sorry. It was a mixture of typing/thinking error. Of course, the spectrum goes only up to +x. Thanks, regards |
