https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Active load noise https://designers-guide.org/forum/YaBB.pl?num=1252763445 Message started by raja.cedt on Sep 12th, 2009, 6:50am |
Title: Active load noise Post by raja.cedt on Sep 12th, 2009, 6:50am hi, can any body please tell me why active load thermal noise is more than passive resistor noise. From math i got to know that noise depends on ratio of V and I. But i am expecting some intutive answer. thanks, Rajasekhar. |
Title: Re: Active load noise Post by MarcoC on Sep 14th, 2009, 12:49am Hi, I will try to answer. In a passive resistor there is -approximately- only one physics noise source: the thermal motion of electrons. In an active load the noise is due to many factors: the thermal motion of electrons in channel, the dangling bounds on the oxide-silicon surface and -in very short channel MOS- we can see also shot noise. Morover, in active loads the R value is not constant. This is my own answer to why active loads have more noise then passive loads. I hope this is clear. Best Regards, MC |
Title: Re: Active load noise Post by raja.cedt on Sep 14th, 2009, 1:21am hi, thanks for your answer..but even if you consider only thermal noise of the channel then also active load is main contributor...you can derive also... thanks, rajasekhar. |
Title: Re: Active load noise Post by Mayank on Sep 14th, 2009, 5:53am raja.cedt wrote on Sep 12th, 2009, 6:50am:
Hi, An active load is a voltage-dependent resistance which introduces non-linearity effects into the circuit ( Total Harmoic Distortion increases ). also as in one of the replies above, an active device introduces thermal noise whose magnitude is proportional to γ - a parameter that scales based on channel lengths. [ nearly 2/3 for long channel , nearly 1 for short channel ] Also, flicker corners vary with different processes, that also decides the total thermal noise contribution. Accounting for all these factors, total noise from an active load should generally be more than its passive counterpart. Hope this extends the above post by MarcoC & explains your query, thanks, Mayank. |
Title: Re: Active load noise Post by MarcoC on Sep 14th, 2009, 6:20am Quote:
This is a good answer. My post was quite generic. ::) Thanks Mayank, I could not be more exhaustive! |
