https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> PNP base doping variations https://designers-guide.org/forum/YaBB.pl?num=1253210982 Message started by cmos.analogvala on Sep 17th, 2009, 11:09am |
Title: PNP base doping variations Post by cmos.analogvala on Sep 17th, 2009, 11:09am I am designing Bandgap Bias gen circuit using UMC180 technology. I have following questions. 1. The process has only parasitic PNP BJT. How to consider variations in base(Nwell) doping ? The foundry provides only one model file for BJT with no variations information. 2. Which model parameters of BJT can vary due to process variations ? What is the amount of variations in these parameters ? 3. In all if I want to consider all the type of variations and make sure that the designed circuit works on silicon what all I should consider apart from checking the circuit for all MOS and Resistance variations given by their model files. ? -CA |
