https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Two Calculator Functions -- rmsNoise and spectralPower https://designers-guide.org/forum/YaBB.pl?num=1254800544 Message started by ywguo on Oct 5th, 2009, 8:42pm |
Title: Two Calculator Functions -- rmsNoise and spectralPower Post by ywguo on Oct 5th, 2009, 8:42pm Hi Guys, I try to caluclate SNR of a DAC output in Cadence Calculator. Can you please explain the two Calculator functions? Quote:
Is this function for AC signal only? Quote:
Why does this function needs two argument, voltage and current? How does it culculate the spectral power? Best Regards, Yawei |
Title: Re: Two Calculator Functions -- rmsNoise and spectralPower Post by Andrew Beckett on Jan 3rd, 2010, 3:33am Yuwei, Rather late reply, but for the record... rmsNoise uses the results from a noise analysis, and computes the root mean square of the noise output. spectralPower this needs both the current and the voltage (so it can compute the power, it needs both the voltage and current, since this is coming from an AC analysis). It calculates 0.5*real(V*conjugate(I)) . Regards, Andrew, |
