https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> calibre PEX extraction warnings https://designers-guide.org/forum/YaBB.pl?num=1255708639 Message started by lhlbluesky_lhl on Oct 16th, 2009, 8:57am |
Title: calibre PEX extraction warnings Post by lhlbluesky_lhl on Oct 16th, 2009, 8:57am 1 when PEX extraction(calibreview), it has the following warnings: unable to find a map for port "R_" on the template for cell "SH1" "R_" will NOT be ported for this cell unable to find a map for port "S_" on the template for cell "SH1" "S_" will NOT be ported for this cell what is the meaning? and not every port can't be ported, for my cell, only three of fifteen can't be ported, the other is correct. besides, 'template file canot be read' is another warning. 2 sometimes for some cell, the following warnings: pin not connected for cell AMP_1 (30) local nn=18 net num=10 pin_layer=593 seed_layer=18; how to solve the two problems, if i don't use template file(.stl) for the first one, then will it be ok? how to do? pls help me. thanks. i also want to say, my lvs check is ok. no error exists. thanks in advance. |
