https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> pole zero analysis of bandgap voltage reference https://designers-guide.org/forum/YaBB.pl?num=1256284691 Message started by vamshikrishna on Oct 23rd, 2009, 12:58am |
Title: pole zero analysis of bandgap voltage reference Post by vamshikrishna on Oct 23rd, 2009, 12:58am Can someone tell how to estimate the pole zero in the bandgap circuit (2)shown here. Please point me to any references dealing with stability analysis of bandgap circuits (pole zero estimation) I dont understand the need/advantage of using the additional resistors r1 and r3 in the fig (2) In fig (2) can we also take the o/p reference at the other end (above resistor r1)? If so which one is better ? Thanks, vamshi |
Title: Re: pole zero analysis of bandgap voltage reference Post by raja.cedt on Nov 5th, 2009, 6:32am hi, R1 mainly to reduce systemic offset in current mirrors R3 is to adjust op amp common mode voltage, please refer this pap '' Design Considerations of Recent Advanced Low-Voltage Low-Temperature-Coefficient CMOS Bandgap Voltage Reference'' Thanks, Rajasekhar. |
