https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> help on second order effect! https://designers-guide.org/forum/YaBB.pl?num=1256311292 Message started by kibby on Oct 23rd, 2009, 8:21am |
Title: help on second order effect! Post by kibby on Oct 23rd, 2009, 8:21am if the function of mos fet in saturation region is used: i=1/2*ucw/l*(vgs-vth)^2 which ignore the second order effect; to analyse the character of gm''(the second derivative of gm) of a simple full differential amplifier,then is the result helpful for design? or it is unreasonable? why? thx~ |
Title: Re: help on second order effect! Post by Riad KACED on Oct 23rd, 2009, 10:42am Hi Kibby, Yes, this is a reasonable approach for hand calculation. This is the way every designer goes calculate the first-step transistors. The second stage is to run a Spice level simulation, using Spectre, Eldo, Hspice ... etc. Simulators using models like BSIM3/BSIM4/PSP DO NOT assume any approximation at all, they give you the 'exact numbers' which are likely to be different from your hand-calculation. Cheers, Riad. |
Title: Re: help on second order effect! Post by kibby on Oct 24th, 2009, 4:23am thank you for your help~ |
