https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> differential current source https://designers-guide.org/forum/YaBB.pl?num=1257659259 Message started by harryhu on Nov 7th, 2009, 9:47pm |
Title: differential current source Post by harryhu on Nov 7th, 2009, 9:47pm How to creat a differential current source? If using balun, how to build the topology? By the way, I am building a fully differential TIA test bench? Thank you in advance if anyone with experience can provide any suggestion. |
